JD 2010 Diesel??????
Ponchobro
06-02-2005 13:31:28
What is so bad about the 2010 diesel. I just looked at a nice used one for $5000. Should I stay away??? Thanks
jan nelson
06-15-2005 21:50:16
 Re: JD 2010 Diesel?????? in reply to Ponchobro, 06-02-2005 13:31:28
The engine can be rebuilt in frame if needed. I use mine in the Olympic Mtns and have NO trouble with cold starts. I would be more concerned with the dry clutch steering if not used frequently than the diesel design. WRT to parts and service availability, I have had no problems here either, though parts are ver ymuch overpriced...
I'd agree with the price being too high. Offer $3000 and plan on spending the other $2K to sort the dozer if you have some wrenching skill. Otherwise, save the money and just hire a dude to do work using HIS dozer as needed... money in your pocket then.
Jan
Tx Jim
06-03-2005 04:17:44
 Re: JD 2010 Diesel blocks in reply to Ponchobro, 06-02-2005 13:31:28
1010/2010 diesel blocks are prone to cracking between cylinders.They are HARD to start below 50 degrees.Spend your $5000 on a 1020/2020.Tx Jim
Dan50
06-02-2005 19:57:57
For an interesting read on the 2010 diesel, go to the left side of this page. Under Research % Info, click on articles. Then scroll down to Restoration stories. A guy wrote a 4 part article, very interesting, which details the time, parts and money he sunk into restoring one of these.
-Dan
msb
06-02-2005 19:34:00
Listen to these guys.The precombustion engines usually operate at a 12 to 1 compression ratio and at the ratio,a lot of the fuel goes unburned with a lot of slobbering to boot unless the engine is operated at peak effeciency which almost never happens.Most of them were had to start especially in cold weather.They are also proned to make a lot of racket when running due to the precombustion chamber design.Definitely NOT one of Deere's better engine designs.Buick& Deere might have been about $500 too high in his estimate on its value.
billde
06-02-2005 18:07:52
avoid it like Anthrax!
buickanddeere
06-02-2005 14:32:47
What serial number? The last year of production was much improved but it was still a 2010. Hydraulics and pto for a couple of items. The deck plate diesel with precombustion chambers requires more service than the 20 and later serie sengines. The gas 1010 and gas 2010 engines were OK. The price is about $4500 too high.
