JD 1530 Loader Hydraulics-Need advice
Joe Kelly
06-02-2005 07:13:18
While bushhogging I broke the two hydraulic lines that lift my JD 143 loader. The bucket would still operate as would the 3 pt. hitch hydraulics.
I had replacement hoses made up and have installed them. I also topped off the hydraulic fluid. The loader will operate up and down but is somewhat erratic. I am assuming I need to bleed the hydraulic lines to the two cylinders. Is that correct and if so do I simply loosen the line connections at the cylinder, raise the loader and tighten the lines (like one would bleed the brake lines on a vehicle)?
Thanks for any advice.
Joe
ck92
06-02-2005 07:26:12
 Re: JD 1530 Loader Hydraulics-Need advice in reply to Joe Kelly, 06-02-2005 07:13:18
just keep operating it and checking fluid level--it should fix itself
Hayfarmer
06-02-2005 07:18:46
If you just operate the loader up and down a few times it should clear up if just air in the lines. Will probablyhave to top off the level again after air worked out.
06-02-2005 07:45:05
 Re: JD 1530 Loader Hydraulics-Need advice in reply to Hayfarmer, 06-02-2005 07:18:46
Thanks for the responses..... I really appreciate y'all's help.
JK
