Update on my 3020 carb.
Jim@concordfarms.
06-01-2005 19:01:37
Thanks to those who responded to my questions last week about overhauling the Zenith carburetor on my 3020. It wasn't easy or cheap, but it's running the best it ever has. I replaced the accelerator pump, check valve, float valve and seat, accelerator jet, and all the gaskets. Total of 105.00 for the parts from mother Deere. I think the accelerator jet was the biggest culprit. It has a check valve inside it that was allowing air to pass both ways. It's a little jet that sticks straight up into the venturi from the bottom of the bowl. I took it out on the county road yesterday evening, put it in high gear, and mashed the foot throttle to the floor. Never coughed or staggered a bit. Went out and tedded 40 acres of hay this morning and it ran like a champ. Wish I hadn't put it off for so long. Jim.
Larry in WNY
06-02-2005 09:43:41
 Re: Update on my 3020 carb. in reply to Jim@concordfarms., 06-01-2005 19:01:37
Jim,
Are these the parts you replaced:
Pump - AR13022
Jet - AR13031
I have a Zenith on my 3020 and had a dealer rebuild it, but it still runs poorly. Not sure if these parts were included in the rebuild. Thanks.
Larry
Jim@concordfarms.
06-02-2005 13:30:40
 Re: Update on my 3020 carb. in reply to Larry in WNY, 06-02-2005 09:43:41
Larry - Yes, those are the numbers I used. Also, the check valve under the pump is AR13030. Jim.
