1520 transmission problem
bootz421
06-01-2005 11:17:52
My 1520 JD does not have any power. trans fluid is ok, losened the clutch. The tractor will move but when I put the bucket on the ground it will stop, the tractor will continue to run just fine. Any help will be appreciated.
cannonball
06-02-2005 05:04:14
 Re: 1520 transmission problem in reply to bootz421, 06-01-2005 11:17:52
need more information...does it have reverser...what did you do to clutch..more information would help, there are losts of good people to help you here but they and i need more information....have nice day may god bless
bootz421
06-05-2005 07:40:28
 Re: 1520 transmission problem in reply to cannonball, 06-02-2005 05:04:14
The problem started when I was moving some dirt with my frontend loader. I dropped the dirt in a pile and released the clutch and it would not move. Later in the day I started it up but the tractor would move very slowly. Gears 1-4 would drive the tractor slowly 5-8 the tractor would not move at all. the reverse gears 1-4 would move the tractor slowly. The cluch: I adjusted the rod on the outside of the tractor to give it more slop but it did not work. The tractors motor runs just fine it does not bog down when I put it in gear and release the clutch. I checked the Hydrolic fluid and it is fine. I hope this is more info that you need to help me thank you
