1020 vs 3010
daletour91
06-01-2005 11:06:57
Hi all..I am looking for a tractor and i ran accross a 1020 that looks like it is in great shape.The guy put on new back rims and rubber. The 3010 i do not know much about i need to look at both tractors but he is going to send pics of the 3010..They are both gas..tyey are asking $4400 for the 1020 and 4800 for the 3010..Any imput would be great.
Thanks mike
Leroy
06-02-2005 18:28:48
 Re: 1020 vs 3010 in reply to daletour91, 06-01-2005 11:06:57
1020 is a 38 HP utility tractor and 3010 is a 55 HP (Unless Repowered) agricultrual tractor built for use with mounted corn pickers and other heavy equipment
ck92
06-02-2005 07:17:02
I own both a 1020 diesel and 3010 gas. If you plan on bushogging with the 3010 then don"t buy it. The 10 series have a shear pin inside the rear end in the pto shaft that is very, very, very easy to shear with a bushog but it is not easy to repair--takes about two days to seperate tractor and repair. Other than that the 3010 is a great tractor. The 1020 is also a great tractor-just small and doesn"t have a great lifting capacity. The 3010 will also have power steering and not all 1020s will.
3010 Ken
06-02-2005 04:36:21
Morning Dale;I don't know anything about a 1020 but I do own a 3010 that I would'nt take a gold nickle for.I use it for mowing with a 10'bushhog and various other implements.Mine is diesel.It's comfortable and it will go as long as I want to stay in the seat and steer it.Kenny
Ben.So.Tex
06-01-2005 19:21:18
I would go with the 3010 More bang for the dollar.Will do the small stuff and than has a set of Ba// for real work. See if you can demo them.. and then you decide.
TG
06-01-2005 13:35:28
Of course, if you're not moving snow, the tractor best for you depends on what you need one for.
The 1020 is newer than the 3010 and the 20 series is considered by most to be a superior tractor to the 10 series.
I have a 1020 gas for use around the house/small pasture that I absolutely would not sell, but I also have a 4020 at the farm for heavier use.
Gerald J.
06-01-2005 20:44:17
 Re: 1020 vs 3010 in reply to TG, 06-01-2005 13:35:28
There's not nearly the quality difference between the 3010 and 3020 as there is between the 1010 and the 1020. Most 1010 were really bad tractors hard to repair because its hard to find special engine parts.
The 3010 and early 3020 take the same Deere shop manual, the main difference is in details like engine bore.
Gerald J.
Gerald J.
06-01-2005 13:08:49
Do you want to play mowing grass and moving snow or do you want to work?
The 1020 clears the ground by 10 or 15 inches, the 3010 by 25. The 1020 struggles through snow drifts with a loader, the 3010 drives over them.
30 hp vs 65 hp.
You do need a 9' or taller garage door for the 3010.
Gerald J.
Dr.EVIL
06-02-2005 08:45:49
 Re: 1020 vs 3010 in reply to Gerald J., 06-01-2005 13:08:49
3010-Gas = 65 HP..... Yeah Right.... If it hasn't been rebuilt in the last 30 yrs try about 40 TOPS! Uncle had a 3010-D, and after Really turning the inj. pump up it would just stay ahead of His 350 gas Farmall pulling the same size equipment. 3020 gas was normally 65-70.
daletour91
06-01-2005 18:23:25
I will be using it to clear scotchbroom put in fence posts and drag a few trees around that need to come down..I have 10acres that i need to clean up
1020gas
06-02-2005 07:45:02
 Re: 1020 vs 3010 in reply to daletour91, 06-01-2005 18:23:25
This will be my second year using a 1020. It"s a really well built reliable utility tractor. At 38 PTO horsepower it has no problem brush hogging heavy fescue and will pull uphill with ease. I do have front suitcase weights on it and it"s really stable
