JD 420C
Land Clearer
06-01-2005 05:22:55
I just bought a '56 420C to use in a woodlot we're clearing and want to have it serviced prior to hauling to the jobsite. I have already been over the undercarriage and have that in good shape.
I'm thinking that the engine could use a tune up, to include: spark plugs, spark plug and distributor wires, distributor cap, points, condensor and a rotor. Are there any other parts that I should consider changing to bring this machine up to a reasonable point of reliability, e.g., coil, magneto, etc?
I'm also thinking about changing belts and radiator hoses and having the radiator flushed. Would flushing this radiator be a good idea or should I take the radiator out and have a radiator shop look it over and do whatever it needs?
In addition, I am going to change the fluids, oil, transmission oil, rear gear oil, and hydraulic oil; as well as any respective filters.
Can anyone offer me any insight or suggestions for any of the above?
CPeter
06-01-2005 06:00:07
 Re: JD 420C in reply to Land Clearer, 06-01-2005 05:22:55
Welcome to the club. I bought my first 40C 30+ years ago to do the same thing. The most important thing to know is to keep the machine tight, make sure that the bolts that hold the parts together are up to torque specs and kept that way. When things start moving around, things break.
In the transmission and final drives, I use 140 wt GL-1 gear oil. If the seals in the rolls and idlers are still good, they also should have the same 140 wt oil. If not, pump them full of chassis grease and add a little now and then. The grease goes in through the funny looking "button" fittings on the ends of the axle.
As far as a tune up, if it is running good now, do NOT replace the condenser. Good new ones are hard to find. These tractors are hard on points and plugs. My experience is to run them HOT. I use a 195� thermostat. This seems to work best for me. You may want to try a little cooler, depending on where you are and how hot it gets. I use Rotella 15w40 oil, but everyone has their own opinion. On spark plugs, Autolite 216 or Champion H10 (or H12 if you have fouling problems). Get a carb kit. Roberts Carburetor is a good source. If you replace the plug wires, use solid metal core, not carbon cored ones.
Most important!!!!
THIS IS NOT A D-8 OR EVEN A JD 450!!! Go slow and easy and you can do a lot of work with it. Remember it is 50 years old and already done a lot of work.
CPeter
Henry J
06-01-2005 05:57:23
Land Clearer
If the hoses are bulgy and soft from grease or whatever or hard as a rock, they need changing as a precaution. With the hoses off, that is if the radiator did not show leakage initially, i would run some water from the garden hose fron the top down in the radiator and from the bottom up - use caution with the pressure.
If you havn't got it yet, I would recommend the operators manual as a minimum. I noticed in my books on the wheel tractor it also gives stuff about the C like adjusting track etc.
