Clutch repair
Mike
02-24-2004 16:47:28
Has anyone tried to rebush the clutch levers and the fork bearings on the old two cylinders with any success?
bent
02-25-2004 06:54:40
 Re: Clutch repair in reply to Mike, 02-24-2004 16:47:28
I just finished doing the entire system. I replaced the bushing on the clutch lever and had to build up the handle itself. I had a machine shop install bushings in the fork bearing housing and build up the shaft. Fortunately, the yolks on the linkage were okay and new pins took most of that slack out. Clooney's statement about the oversize pins is true, they look funny. If you have the Yost book about restoring JD tractors, you can see some good examples of the fork rebuild. It is worth the time and effort to rebuild these items, it makes the operation that much sweeter!
Clooney
02-24-2004 17:12:37
Mike, sure I do it on most every one I restore..
~On the clutch lever?.. Deere still carries the brass bushing for the bottom of that hand lever but in most cases the pivot bolt is also worn & the hole in the clutch lever is worn oval.. I usually make a new brass bushing then pres it in tight, then ream the hole to fit the pivot bolt..
~On the fork bearing?.. That depends on the machining equipment you have available & how bad the wear.. Again the upper bearing hole wears egg shaped & to properly fit a bushing the upper hole should be bored out on a mill, then a brass bushing pressed in then the bushing re-bored on center to fit the fork shaft.. Another way is to braze a brass build-up on the top of the fork shaft then grind or machine that to fit the worn hole in the fork bearing housing..
~I think you will also find a lot of wear & slop in the clutch linkage pivot pins.. On those, I ream the holes out round & make new pins that fit those reamed holes.. You can buy the next size larger pins but those are so large they look way out of place due to the large pin heads... I have used metric bolts that are slightly larger then turned the bolt heads round on the lathe to look like the original pin heads [they look real good & can't be distinguished from originals..
[email protected]
