JD 4020 hydraulics????
Brad in VA
05-31-2005 17:41:58
Hello all, i have just purchased a 1968 4020 with a single set of remotes... My question is that i need two for the disc bine... How much of a pain in the butt would it be to add a second set or should i sell this one and get another? Thanks Brad
ck92
06-02-2005 07:35:20
 Re: JD 4020 hydraulics???? in reply to Brad in VA, 05-31-2005 17:41:58
takes about 2 hours and around $1000. but you may want to purchase a jd service manual too.
Gerald J.
05-31-2005 20:49:12
Salvage yards post prices in their catalogs for the control valve and the coupler, but not for the pipes that go between. I don't think there's room under the operating platform for rubber lines, so you almost have to get the proper steel lines from Deere or the salvage yard.
I know Eichenborg and value built show those parts in Iowa. $250 or 300 each piece.
The alternative I've often considered is to tap the 4020 pressure line (replace the elbow in front of the brake pedals with a T, that's full pressure at full flow) with return to the transmission oil filter cover and hang a valve on the right fender. I'd put a shelf there with the valve underneath and the hoses going down with the handles reversed. Then about $125 for a Pioneer double connector (9500-4) at the back.
I've already tapped the pressure and return which I use for a loader. I have two ports plumbed in, one for loader the other for a back hoe. I put a flow restriction valve in each because neither needs 21 gpm, they are much more controllable with 4 or 5 gpm.
The added valve has to be closed center. Then you can add as many as you want.
Gerald J.
ck92
06-02-2005 07:36:26
 Re: JD 4020 hydraulics???? in reply to Gerald J., 05-31-2005 20:49:12
rubber lines will fit
msb
05-31-2005 19:54:41
Your easiest approach would be to buy a Fasse or Multiplier valve and use the single that you have. The other alternative would be to try finding a second remote in a bone yard,but they won't be cheap.I installed dozens of them(new) back in the 60s for $110 a piece.
