466 rear main seal
hogman_2002
05-31-2005 16:38:03
I'm rebuilding a 466 on a 7720 JD combine. I'm now installing the rear main seal and have a few questions. The original seal is RE22764, but in the rebuild kit I got a RE520036, which is an improved seal. The RE22764 calls for installation tool JDG477(85) and JDG 478. The RE520036 calls for tools JDG477 and JDG478. I went to the local JD dealer and the service manager gave me the JDG 477(85) and JDG 478 to install the seal. After using it I found that the wear ring is about 1/8" from being flush with the end of the crankshaft. In other words, it sticks out too far.
When I took the tool back I asked the service manager and he said that's the way it is. He said when I install the flywheel it will push the wear ring the rest of the way on.
This doens't sound right to me. I sure would hate to have to pull the motor again because of a leaky rear main seal. Anybody that has any experience, please feel free to chime in.
Thanks
hogman_2002
06-02-2005 10:38:16
 Re: 466 rear main seal in reply to hogman_2002, 05-31-2005 16:38:03
I ended up going to another dealer and asking them about installing the rear main seal. They gave me the same exact same tools the first dealer gave me(JDG478 and JDG477(85). One of the mechanics told me the seal will be just below the flange on the crankshaft when installed correctly. So I went home and tried it again. Sure enough the seal went on like it should. Apparently there is something wrong with the installation tool from my local dealer.
G/MAN
06-01-2005 07:33:42
The wear sleeve should be flush with the crank flange when the seal is properly installed. Sure, the flywheel may push it the rest of the way one, but I'd rather it be flush before. I'd get the tools that are called for. I'll check our seal installer, because I know it works on the older "improved seal" and the latest and greatest one they have now. There have been at least three different rear seals used for the 400-series engines that I know of.
Bob
05-31-2005 21:51:21
Where you're at now, I see no reason the flywheel won't push the ring on. Or, is the seal 1/8" too far out, also? (Did you use retaining compound on the sleeve?) You could put the flywheel on, draw up the bolts evenly and torque them, and then remove the flywheel again to verify the ring went on evenly, without damage
matthies
05-31-2005 20:15:22
I'm not trying to be smart, but did the tool bottom against the two bolts that hold the inner piece to the crank, instead of between them? Just a thought, and did the seal go flush with the housing, I'm thinking it goes a little below flush. good luck chris
Tom (Ks)
05-31-2005 20:01:05
I have installed many many rear seals in 404 and 466's, when pushing the seals on with the installer, it allways pushed the sleeve all the way on. Sometimes you have to tighten that nut pretty good to get it flush. Don't depend on the flywheel to get it on all the way. I would go back and borrow the tool again and see if you can get it further in.
