JD 2640 hydraulics quit HELP
Willy P
05-30-2005 19:49:32
I am having trouble with my 2640 tractor hydraulics It will run awhile with the pto running and then it looses all the hydraulics,steering lift etc. Today I moved some rolls of hay and after about 30 minutes the hydraulics quit and nothing would work not even the pto. What could be the problem? Any help would be appreciated. Thanks
Willy P
06-01-2005 04:19:22
 Re: JD 2640 hydraulics quit HELP in reply to Willy P, 05-30-2005 19:49:32
I have changed oil and filters and cleaned the filter screen,Thanks for the help.
Tx Jim
05-31-2005 04:16:59
Willy have you changed hyd.filter and cleaned sump.screen?Tx Jim
bob2003
05-30-2005 20:27:29
Read my posting entitiled "I NEED HELP - still have intermittent hydraulic lo - bob2003 19:27:13 05/30/05" about two post prior to yours.
There are a number of diagnostic things I have done trying to search out the answer to my problem, but it may give you some answers.
You are free to write directly to my email if you have further questions.
warren kearns
06-15-2005 20:17:05
 Re: JD 2640 hydraulics quit HELP in reply to bob2003, 05-30-2005 20:27:29
my 2640 does the same thing i have changed the filter under transmision and the one in the pump on front of tractor one thing i did find was water in the hydrolic oil that gets in from the gear shifter boots i stopped the water but the pto still does not work does anyone know an easy way to check the pto clutch pack
