Subject vehicle: JD 750, 4WD, with front loaderHydraulic system works fine then after about 20 minutes of continuous use (engine, not continuous use of hydraulics) the system will begin to shutter on operation then will progress to complete failure. Shutting engine down for as little as a couple minutes resets this cycle, then it is good for another twenty minutes. I have drained all fluid and replaced it with new. The screen is clear; this model does not have a filter. I checked the rubber hose that connect the 7/8th pump intake lines on the left underside of the tractor; it does not have any holes, is not kinked, nor is in collapsing from pressure. Using an air compressor (after disconnecting both ends) I blew air through the line from where the rubber hose connects and the pump-All clear. I replaced both �O� rings; the one going into the pump and the other on the cover that is by the screen. Disconnecting the output line from the pump, the fluid is ejected with full force. The hydraulic stop valve is open, the bypass activates with the bucket is tilted backward to its extreme, and the lines are not overheating � just barely warm to touch. The fluid level remains constant as does the engine oil, thus no fluid is being lost into the engine. Thanks MSM on your post, however, it did not reslove the issue. I do not have quick connects, and proble continues even after disconnecting the line to the front loadrer and rerouting it back to the main pump. I�m stumped and so are the JD mechanics. Does anyone have any ideas???? My direct email is [email protected]
