G runs like crap
720 billy
05-30-2005 13:02:24
i have a G it miss and pops you put it in a pull and it chokes out well i changed the dis. and put a mag. it ran the same i changed the carb. it ran the same i sprayed starting fluid under the in take it didnt help i put in new plugs it didnt help it wont idle ok can you all help well maybe i need a framall no the broke johndeere is sill better than a funky red farmall
Paul from MN
05-31-2005 08:53:33
 Re: G runs like crap in reply to 720 billy, 05-30-2005 13:02:24
Are you 100% sure that you have the correct plug wires? It sounds like you may have resistor wires.
Mike M
05-30-2005 19:55:21
If that other carb. and mag. run fine on the other tractor then I'd start looking for worn cam bearings.
JGC
05-30-2005 19:34:17
I had a similar problem with a "D". It turned out to be a lot of small problems that caused it to run poorly.
Here is a list of several that come to mind!
Carb - my throttle plate looked ok, but on closer examination it was worn.
The fuel level was off even though I set the flow depth correctly - the best test is to connect a piece of clear plastic hose and fitting to the drain cock on the bottom of the fuel bowl and observe the actual fuel level with the carb assembled and mounted on the tractor.
- I removed ALL of the plugs and completely stripped the carb down, then had it "tanked" by an engine shop, then I used the long bits to clean the passages.
Then I checked with compressed air to make sure that every 'circuit' inside the carb was clear. - Are you getting a pencil-lead diameter continuous stream of fuel for 60 seconds when bowl drain cock is wide open.
- did you remove the nozzle and carefully check that all of the small holes were clear.
- are the throttle bushings and shaft a close fit.
- The hole in the throttle lever that takes the throttle shaft was worn oversized and egg shaped. I carefully enlarged it with fractional and number drills and fitted a bushing made out of extremely thin-walled tubing that I bought at a local hobby shop.
Fuel - is the fuel fresh, and treated with stabilizer?
Air Cleaner - is the air cleaner serviced and completely clean.
Plugs - I tried hotter Autolite plugs which worked for me.
Wires - I replaced the wires with new solid core wires.
JD720
05-30-2005 19:22:03
You might check your valve clearances.If you know that the carb is good you may have your valve clearance too tight. Is this a new rebuild or did it just start running this way ? If it just started running this way you may need a valve job.
Garland
05-30-2005 17:31:06
Billy your carb needs to be throughly cleaned out send to roberts Carb. Service he's got some little drill bits to clean out the little passages and this should get you going. Gman
720 billy
05-30-2005 18:25:33
 Re: G runs like crap in reply to Garland, 05-30-2005 17:31:06
well ive got the bits from roberts ive cleaned all the little places out took the peice out the bottem and cleaned it to
