60 Duplex carb/manifold setup
potentpuller
05-30-2005 11:33:23
Need more power out of an A and I was wondering if a Duplex carb and manifold off of a 60 would fit on an A head. If not, will a head off a 60 fit on an A block. It has 42 hp right now and am looking to get into the 50-55 hp range.
The Potent Puller
Drew
05-30-2005 12:45:49
 Re: 60 Duplex carb/manifold setup in reply to potentpuller, 05-30-2005 11:33:23
A 60 head will bolt right on a styled block. From the factory, only one barrel feeds one cylinder, so to get the most benefit, the plentum needs to be cut out so each cylinder can pull off of BOTH barrels. Since your goal is only 55hp I'm guessing your engine isnt huge and therefore you wont see the benefits that a big engine would see, but it should help a little bit.
potentpuller
05-30-2005 16:54:23
 Re: 60 Duplex carb/manifold setup in reply to Drew, 05-30-2005 12:45:49
Its got an unstyled A block bored .130" over. My goal is not nessarily 55 hp, if I gan get more I'll take it but I want to get 55 minimum.
The Potent Puller
Drew
05-30-2005 19:57:21
 Re: 60 Duplex carb/manifold setup in reply to potentpuller, 05-30-2005 16:54:23
With an unstyled block, you are pretty much stuck with the stock head, which isnt necessarly bad since you dont have the swirl part of the head to contend with like you do with a styled head. I would get a gas manifold and make sure it is port matched to your head. Roller rocker arms will get you a few hp. A DLTX 51 or DLTX 71 can be opened up and get another few hp. Have you put in a styled crankshaft? That's an easy .250" stroke over an unstyled shaft. I'm guessing 55-60hp at tops is all you can get without digging in the back pocket some more.
buickanddeere
05-30-2005 11:47:17
The factory head and a gas manifold will make an easy 55HP with a little cleaning up. Less chance of getting disqualified too.
potentpuller
05-30-2005 12:24:27
 Re: 60 Duplex carb/manifold setup in reply to buickanddeere, 05-30-2005 11:47:17
I'm not too woried about getting disqualified as we have our own dyno and our club's only rules as far as engines are a horsepower limit, 45 hp for 4500# class and 55 for 5500# class.
The Potent Puller
