1946 John Deere B
Farm w/Junk
05-30-2005 06:39:48
Hi all Im working on my 1946 B and tore it apart to replace manifold/ paint and removed the fanshaft. Question is is there a gasket for the fanshaft to gov housing connection? If so how thick? Doesnt look like there was one probably for the gear lash but wanted to make sure. Thanks
Matt
John T
05-30-2005 06:58:55
 Re: 1946 John Deere B in reply to Farm w/Junk, 05-30-2005 06:39:48
Theres actually a set of shim/gaskets there used to properly mesh the bevel gears heels evenly (front n back). Then theres similar shim/gaskets used on the governors horizontal shaft bearing to adjust backlash (left to right). If mis matched she can whine and/or too much backlash. Those gears need to be a matched set n adjusted right regardless if new or a used matched set from a junk tractor.
John T
