Best first tractor
Mikeloff
05-29-2005 22:14:51
Hello,
I'd like to get your opinion on a good first tractor to restore and use. I think Farmalls look the best
but my brother recommends Case because they are good
old work horses. What do you guys think?
Thanks,
Mike
partner
05-30-2005 10:05:45
 Re: Best first tractor in reply to Mikeloff, 05-29-2005 22:14:51
I would go with the Case, they are much more reliable,easier to maintain, better clutch, remember it took deere 30 years to figure out how to put the engine in line with the tractor.
Henry J
05-30-2005 05:06:22
Mike
I think a lot of it would depend on your needs. Personally I think all the main line antique tractors of that byegone era were reliable workhorses.
However, since you asked on a green board, you need to get a JOHN DEERE. Now the deal is, what are you going to be using it for?
Mikeloff
05-30-2005 07:36:21
 Re: Best first tractor in reply to Henry J, 05-30-2005 05:06:22
I"ll be using it mostly for pulling. Will a John Deere hang with a Farmall or Case in the pulling department? I"ve heard older John Deeres weren"t known for their pulling power. Is this true?
Thanks,
Mike
GNB
05-30-2005 08:17:15
 Re: Best first tractor in reply to Mikeloff, 05-30-2005 07:36:21
NO! That is definatley not true of the older John Deere. I have a 1950 JD A and it will pull the heck out of something. Very good torque. I have a Farmall M and I do have more Farmall tractors but the best pulling tractor I have is the JD A. Tough tractor as is most all of the 2 cylinder John deeres and good pullers! My 2 cents.
GNB
Mikeloff
05-30-2005 08:32:06
 Re: Best first tractor in reply to GNB, 05-30-2005 08:17:15
STOP!!! This much I know is true, a JD A will never pull with a Farmall M or a DC Case. Besides a JD A is too hard to start and the reverse is a little fast.
Thanks,
Mike
tractordave
05-30-2005 15:37:06
 Re: Best first tractor in reply to Mikeloff, 05-30-2005 08:32:06
You are comparing the Farmall M to the wrong tractor anyway! The JD G is a better match to the Farmall M, and I believe the M would have a run for its money there. The HP of the Late A and G are almost the same, but the G has more torque and would go places with a plow that would eat an M alive.
I like ALL the colors of tractors, but don't come to a Green board and start an arguement (re:color war) just to do it.
Dave
TommyT
05-30-2005 09:06:35
Sounds like you only came here to start something. You are correct on the A and M tho. The M transmission will give up before it can stay with the A. Compare the M Farmall and the M John Deere, now there is a good match. TommyT
phil2
05-30-2005 09:53:44
 Re: Best first tractor in reply to TommyT, 05-30-2005 09:06:35
A late model A or B makes an excellent first pulling tractor, but not because of the "green is better than red" thing. It is simply because of the gearing, they have a creeper gear. So you never run out of power, you will always spin-out. You don"t need to spend big bucks on the motor, all you have to do to win pulls is get the balance right & get the tires right.
