830 Puller
Plant Doctor
05-29-2005 17:48:05
My friend and I pull an 830 in the 10,500lb class. The tractor runs strong, but we can not get it to hook up to the ground. It has 18.5 x 34 tires with about 7 psi per tire. We are 300 pounds under weight and intend to add it soon. Any tricks on how to get more traction? The track has to be in perfect condition before I can get the front wheels off the ground before it loses traction. I hate losing to red. There is always an MF with a detroit that takes first place. I am sure that 830 will eat it's lunch if I can get it to hook up to the track. Any and all suggestions appreciated. Thanks in advance.
720Deere
05-29-2005 18:46:16
 Re: 830 Puller in reply to Plant Doctor, 05-29-2005 17:48:05
First off, get a set of wheel weights and get that thing up to max weight. 7 psi sound a little light on the tire pressure. I don't know that type of tire your are running or on what type of track, but 7 still sounds low. Most likely your tire lugs are buckling under and losing traction with that low a pressure @ 10500 lbs. Experiment with your tire pressure and that should help. I would think more like 9 - 10 lbs minimum. I assume you are using the stock drawbar. Is your hitch at max height? If not, you need to get it there. Don't just pull with a clevis, build a hitch.
Pulling the front wheels off the ground is not the effect that you are looking for. That changes the balance and causes you to lose hitch height and therefore weight transfer. If you start to experience this, you will need to shorten your drawbar or add front weight to compensate.
Unless you have a speed limit, that Massey/Detroit is going to eat your lunch every time. I have pulled against them and they have far too much power which translates into ground speed. If the speed limit is 3.5 mph or less you should be able to beat him most of the time.
Plant Doctor
05-30-2005 06:51:54
 Re: 830 Puller in reply to 720Deere, 05-29-2005 18:46:16
Thanks 720Deere, this gives me a starting point. Give me your thoughts on this, I was told to add more weight right in front of the flywheel. The location of the weight is as important as adding the weight?? Any thoughts on this? I don't what to go building a weight bracket if it is not necessary. Thanks again and I will keep you posted on our progress. The next pull is in (I Think)three weeks. I want that MF, the driver is a lady with a real attitude and she keeps winning. We pull on a clay track that gets extremely slippery when wet and it's like a rock when dry. I find the 830 does much better when conditions are dry. I have come in second on several occasions when the track has been dry. Anyway, thanks for your interest.
720Deere
05-30-2005 10:38:53
 Re: 830 Puller in reply to Plant Doctor, 05-30-2005 06:51:54
This MF 98 is starting to sound familiar. Where are you from? If it's the same tractor that I'm thinking of, you're not too far away from me.
As for adding weight in front of the flywheel, I have seen a few brackets built to accomplish this. The neatest that I have seen was made like a hook to slide onto the tractor frame and had several small bolts to hold it in place. Adding weight in the middle of the tractor helps with your front balance without adding it all to the front. It's probably six of one and 1/2 dozen of the other. You won't need as much weight on the front as you would in the middle to create the same balance. I always believe in put as much directly on the rear as you can and as much as you need on the front.
Unless for some reason you don't have the original large front weight on that 830, you should only ever need between 100 & 200 lbs max on the front. If the drawbar/hitch is short enough, most get away with no extra front weight.
Plant Doctor
05-31-2005 04:38:01
 Re: 830 Puller in reply to 720Deere, 05-30-2005 10:38:53
720Deere: I am from South Jersey and generally pull at the Salem County fair grounds. Where do you call home?
720Deere
05-31-2005 08:39:22
 Re: 830 Puller in reply to Plant Doctor, 05-31-2005 04:38:01
I am in Harford County, Maryland, but have come up against that 98 quite a few times. You are going to have a tough time beating her with those South Jersey rules. Rumor is that the rules were written around that tractor. Put that Detroit in a under 3.5 mph class and it can and has been beaten. They used to pull with us at Mason-Dixon until the Jersey pulls got started.
Drop me an email and I might have a few pointers for that 830.
