model 70 is leaking oil and I need help
al finldley
05-29-2005 15:30:00
My model 70 started leaking oil around the bottom of the flywheel cover today. Any suggestions on the cause or repair would be appreciated. Thanks in advance.
Larry806
05-29-2005 19:36:49
 Re: model 70 is leaking oil and I need help in reply to al finldley, 05-29-2005 15:30:00
Pull your flywheel cover off. I think you will find that it is the flywheel seal leaking. With the cover on they look like there leaking at the bottom
Al Findley
05-29-2005 20:18:05
 Re: model 70 is leaking oil and I need help in reply to Larry806, 05-29-2005 19:36:49
To replace the seal do I just remove the flywheel and install the seal from the outside?
