2130 hydraulics fading
Billy Harrison
05-29-2005 08:16:58
My 2130 operates perfectly from cold start. I primarily use it for bushhogging about 10 acres. From cold start it runs normally for about an hour on an 80F day or roughly 45 minutes on a 90F day then the hydraulic begin to fade. First, the steering then the PTO. I can shut it down for an hour or so and go back and repeat the same scenario all day. The engine temp stays between 160 and 180F no matter how hot the day is. It has been doing this for about 5 years now. The first time it did this I changed the hyd. fluid and filters. The filters were clean and I got no change in the symptoms. I sent it to 2 local JD dealers who also changed the fluid and filters and brought it back and declared it fixed! NOT! I finally gave up and figured that eventually something would fail that could be diagnosed and repaired. But after 5 years the symptoms are unchanged. Anybody got a clue?
buickanddeere
05-29-2005 08:59:46
 Re: 2130 hydraulics fading in reply to Billy Harrison, 05-29-2005 08:16:58
There is a screen as well as the oil filter. It does sound like a tired trans charge pump or main front pump. Do have any way to monitor trans oil temp vs. time and verify this is an oil temperature related failure? Do you access to pressure gauges to monitor the charge and main pump pressures? The pto clutch should be a dry two stage operated by pushing the clutch foot pedal down past the trans clutch disengage position. There will be a little flat pto lever on the left side of the trans case between the clutch foot pedal and diff lock lever. It won't affect the hydraulics but have you greased the clutch recently?
Billy Harrison
05-29-2005 10:02:42
 Re: 2130 hydraulics fading in reply to buickanddeere, 05-29-2005 08:59:46
I can get the necessary equipment to monitor temp and pressure on Tuesday. I haven't greased the clutch in a couple of years.
Gerald J.
05-29-2005 08:43:09
I believe the main hydraulic pump is worn. And as the oil gets hot it gets thin and the pump pumps less well. Though it could be from a leak. Leaks from high pressure heat the oil more rapidly. Do you have a loader? Does the loader valve leak? Is it an open center valve on the loader with the tractor having a closed center? That guarantees oil heating.
You might cool the oil with an external oil cooler. For that matter is the Deere oil cooler clean?
Gerald J.
Billy Harrison
05-29-2005 10:06:19
 Re: 2130 hydraulics fading in reply to Gerald J., 05-29-2005 08:43:09
I don't have a loader for this tractor. A friend of mine that is a Cat. mechanic also suspects a worn hyd. pump. I had thought of adding a cooler but can't figure where or how to mount one.
Tx Jim
05-29-2005 08:38:34
Billy,what kind of pto does it have?If pto fades probably independant.If it is ind.pto have you tried running tractor for an hr. with pto off? Does 3pt.fade? Tx Jim
Billy Harrison
05-29-2005 10:08:03
 Re: 2130 hydraulics fading in reply to Tx Jim, 05-29-2005 08:38:34
If I run without PTO hydraulics do not fade.
Gerald J.
05-29-2005 11:00:57
 Re: 2130 hydraulics fading in reply to Billy Harrison, 05-29-2005 10:08:03
OK, there's a leak in the pressure lines of the hydraulic PTO clutch, or in the clutch itself. Chase it by finding the hot return line.
Gerald J.
cannonball
05-30-2005 06:55:42
 Re: 2130 hydraulics fading in reply to Gerald J., 05-29-2005 11:00:57
have 2 2130's here and nope no 2 stage clutch ...most likely its the pto leaking or as said above the line leaking... the 2130 is compared to the 2640....have nice day may god bless
aaron345
05-29-2005 17:34:42
I'm pretty sure 2130's had dry mechanically operated clutches. The reason it doesn't fade without using the pto is because its not getting worked hard enough. Check your system pressures including lube presuure (charge circuit)
