Advice Requested - Fuel Bowl Replacement
JGC
05-29-2005 06:07:05
Your adbvice requested, I need to replace the fuel bowl and 3-way valve on my "D". The main tank is 1/2 full of gasoline.
I can drain the gas out, but how do I minimize the risk of exoplosion or fire from all the vapor left in the tank.
I would prefer not to flush it with water!
tractordave
05-29-2005 18:40:04
 Re: Advice Requested - Fuel Bowl Replacement in reply to JGC, 05-29-2005 06:07:05
Order the new parts and drain the tank and replace the parts the same day. Don't smoke while you do it.
Unless you need to coat the tank or otherwise do work on the tank don't worry about flushing it out. If you just want to get any sediment out of there use kerosene to flush it.
Dave
