730D ES oil pressure
CFWelles
05-29-2005 06:03:20
I am getting down to the end of the list of correcting problems on my 730D ES that I bought last fall. Looking for any comment on the adjustment of oil pressure on the motor. Recently I tried to adjust the oil pressure down some using the method discussed in the I&T manual mounting a guage and adjusting the spring loaded screw. I got no response and am thinking that something is jury rigged inside this simple assembly to plug the "T" that this screw is supposed to bleed off. My panel guage shows oil pressure at the top of the guage range even staying up there as she warms up. Should I be concerned about this high oil pressure? Tractor supposedly was majored about three or four hundred hours back and the motor acts like this must be true. Has good power, no smoke, and oil pressure is up there as I pointed out. So my q uestion is from knowledgeable posters here.....Should I make looking into this a priority issue? I am not aware that oil pressure being too high is an issue to be concerned about until I need another oil change and can pull this by pass mechanism out for inspection. Thanks. Charlie in PA
RickB
05-29-2005 09:00:08
 Re: 730D ES oil pressure in reply to CFWelles, 05-29-2005 06:03:20
I had to back my pressure regulator down as far as I could after a total rebuild. I run IH #1 10W diesel oil in it and it runs near the top of the range, verified by a known gauge after the rebuild about 10 years ago. What weight oil are you running? The Op manual calls for 10W or 10w-30 from 0 to 90 degrees F. 5W-30 may be a good choice if you can find it with a decent API C rating.
mike brown
05-29-2005 06:20:33
Mine shows pressure near the top of the guage also. I assumed it was a good thing. I would first get a test guage and check it at the fitting for the tube to the panel guage.
Old guage might not be so accurate.
