Aluminum Pistons From The Factory????????
Old Joe
02-24-2004 13:26:28
Question: Did John Deere ever install aluminum pistons in 2 cylinder model G or 70 engines from the factory?
Paul
02-24-2004 17:06:15
 Re: Aluminum Pistons From The Factory???????? in reply to Old Joe, 02-24-2004 13:26:28
All JD 2 cylinder tractors with gasoline or all fuel engines had cast iron pistons until the 20 series came out. Now if you are talking about a 70 LPgas then yes they did have aluminum pistons. Also the diesels always had aluminum pistons.
F-I-T
02-24-2004 17:04:57
third party image
I know the 70 Diesels used aluminum alloy pistons.
Frank-in-Tallahassee/Pasadena
buickanddeere
02-24-2004 20:24:47
 Re: Re: Aluminum Pistons From The Factory???????? in reply to F-I-T, 02-24-2004 17:04:57
F.I.T if I ever figure out how to post pictures that pretty 720/730 piston needs a mate. Sitting beside me at the moment is the worn piston from our 70D. An out of spec injector ruined it. Worn ring gooves with an overlapping/ broken ring stuck in one of the grooves. Took about 4 HD wash cycles in the dish washer while the wife was away to get the soot and oil off it.
F-I-T
02-25-2004 07:09:46
 Re: Re: Re: Aluminum Pistons From The Factory????? in reply to buickanddeere, 02-24-2004 20:24:47
B&D:
I still have the standard sized ones I removed. I never cleaned them up and tried to measure the wear. You could only see just a bit of like a haze wherer the spray pattern hit the piston for those 7,000 hours. I bet a bad injector pattern would do a lot of damage!
I should clean them up just to see if they were still within limits.
Frank
buickanddeere
02-25-2004 08:44:20
 Re: Re: Re: Re: Aluminum Pistons From The Factory? in reply to F-I-T, 02-25-2004 07:09:46
The raw fuel washed the lube off and the soot from incomplete combustion did the rest. The one bore was almost reusable for a parade tractor if re-rung. The other bore was so far gone it took some careful alignment of the boring bar to cleanup with a 45 overbore. I�ll send a jpeg to you at home of the ruined piston. Has 10,000+ hrs on it. The "Ice Road" and "Hoisting & Rigging" adventures would look good in the stuck and troubled area of this site.
Mike M
02-24-2004 16:31:57
I'm pretty sure that the 70 gas was aluminum from the factory.
Mike M Retraction
02-25-2004 07:56:42
 Re: Re: Aluminum Pistons From The Factory???????? in reply to Mike M, 02-24-2004 16:31:57
The more I think about it. I'm probabally wrong
I think the ones I had were not standard bore.
I think cast iron is correct but the piston ring width is narrower than on the letter series.This explains a differant part number. Pretty sure this is the case with the B to 50 and the A to 60 but don't know for sure on the G to 70.
