2240 hot as the sun
mikeinWA
05-26-2005 21:57:50
Ok truth be told its a Canadian 1630. Identical as far as I can tell to the 2240. I Have run alot of different tractors JDs mostly, and have never been so hot in the station. The fan on this thing blows past the motor and directly onto my left leg. It really gets warm up there. This is my first open station 40 series experience. All the tin seems to be there. Anyone else experience the same thing? The gauge reads fine and after replacing the pto clutches I think I have a good little tilling tractor, but man its hot in that seat. Maybe they make them like that for the Canadian market, its just snow and moose up there isnt it?
John36b-n
05-27-2005 23:32:08
 Re: 2240 hot as the sun in reply to mikeinWA, 05-26-2005 21:57:50
My bet agrees with the post that sumpthins going on there besides hot air from engine cooling. I recall toasting my leg on that series bigtime. Problem was incorrect procedure for checking the hyd oil resulting in low oil level. Made the tranny excessively hot. Does it only get that hot when using the PTO? Hope this helps. And I bet bit of hyd oil applied behing the ear will keep those blackfles away
cannonball
05-27-2005 05:37:43
yes mow hay with a 401b(2440)..lost of heat blowing back...have a large fan and while moving cutting hay you can really get hot..have seen my legs look like sun burn on them, glad i just cut most of the time to noon....get pretty bad here in july(tex)....have nice day may god bless
Jake
05-27-2005 05:18:39
Do you have the rear exhaust option that has the exhaust pipe running under the left foot rest?
Another possibility is an internal hydraulic oil leak. Any high pressure oil leak inside the tractor will generate a lot of heat near the leak. Feel all over the transmission, rear end, rockshaft housing for any areas that are noticeable hotter than the rest.
If the heat you feel is really coming from the fan/radiator maybe you can install a deflector to shield your leg????
Indydirtfarmer
05-27-2005 03:08:15
Got a couple 2440's. No heat problem with 'em.... In fact, I bought #2 'cause I liked #1 so much. VERY comfortable tractor to operate. No explaination for your problem.....
Pete/ME
05-27-2005 02:41:02
The only heat from mine (2240) comes from the footplate which is on top of the muffler, but even then, not too bad. Don't know how the fan can blow air on the op. with the engine, cowling etc. between you and it. Could something else be giving off heat? (Plenty of snow and moose up here in Maine too eh?)
buickanddeere
05-27-2005 01:36:41
Only six weeks of summer and black fly season in Canada. That engine heat feels good any other time. The moose while they will stand for hours watching tractors and equipment. They can only wish to operate machines.
mikeinWA
05-27-2005 23:05:03
 Re: 2240 hot as the sun in reply to buickanddeere, 05-27-2005 01:36:41
Thanks for the replies. Dont have exhaust under the floor board, and I can trace the heat to the fan. It blows back across the left side of the engine and doesnt have anything to block or deflect it. The alternator etc. blocks on the right, but I think its mostly oil cooler on the right. Guess if I hold a Molson in my left hand the problem might go away. I do believe its worse for me because I till at a crawl and its been warm, just never felt anything so direct from any other tractor.
