I agree with Earl that the studs were rolled on the block end for an interference fit, so if you attempt to cut them on a lathe, you'll want to size them accordingly just to be on the safe side. If you use a die, you might want to open up the slot on the die as far as it will go and make your first pass and see what you have for size that way. I have done it that way and had good luck getting a the size of the original. Still use a good sealant as well. On the use of the Grade 5 all-thread rod, if the original studs were Grade 5, I suppose that could be an alternative, but original Deere studs were described as "High-Strength", and I was pretty certain that back then, H.S. meant the equivalent to today's Grade 8, which is 150,000 psi. Also, they were dark colored and heat treated as noted in the parts book, so lacking a Rockwell hardness test, I don't know how hard they were, but I'm still thinking based on how difficult it is to file one (a RC 50-60 is pretty hard to stirke with a good file) that those studs were a bit harder than a Grade 5. I'll have to pull one from a block some day and run it through my old company's met lab, but it were me I'd try to use a meterial that was more like a Grade 8 in strength. It's a "G" which as stock was only all-fuel compression so it is not as critical as a diesel, but those head gaskets like to blow under hard pulling just the same. Now as to new parts here is what I can determine. None of the similar length studs for other models are available either. There was a part for the 720/730 Gas, F2706R, which is 8 1/8", 3/4" stud, but it too, is NLA. Also, the 70 gas, F1217R, is 8 3/8"x3/4" is NLZ. You might try Greg Steven at www.theoldtractorcompany.com. You can get his phone number from there. He probably can get the "G" studs or one of these other part numbers for you. That's about as close as I can get you. Maybe someone has some good used 730 gas ones out there for you. Frank
