# 9 John Deere sickle bar mower
bj207
05-26-2005 18:03:41
Its a 3 pt 6 ft bar. How good are they and what are they worth.I got it on a trade a real good deal.Iam only going too use it for triming along the rock walls. Thanks Bob
James2
05-27-2005 11:49:44
 Re: # 9 John Deere sickle bar mower in reply to bj207, 05-26-2005 18:03:41
I have a 9W in real good shape. Bought the main drive from a junk dealer for $25 and married it up to another bar assembly from a model 9 that already had been rebuilt. Junked the old bar assembly and remainder of the model 9. It's an OK mower, but not worth more than $100-$150, unless you were just trying to match tractor vintage. If you are going to use it much, I would go with at least a model 39 or better yet a model 350.
ChuckW
05-27-2005 04:18:25
the second post speaks of a trailing wheel. I had a #9 3 point and it didnot have a trailing wheel. You sure you're not refering to a #8. I didn't have any problem with the #9. The only thing is the bar will only come up a short distance on banks till you get the pitman chatter. I believe there is a lock tab to prevent a large angle. I have a 350 on my JD and much prefer it...you can mow at the angle....
Jake
05-27-2005 05:11:29
 Re: # 9 John Deere sickle bar mower in reply to ChuckW, 05-27-2005 04:18:25
He is referring to the rear wheel of the tractor. It needs to be moved in to narrow tread for a #9 mower. The #9W mower will work on a wider tread tractor because the cutterbar is offset further to the right to clear the wider tractor wheel spacing.
msb
05-26-2005 20:55:14
They are a good old mower.The model 9 needs to have the rear wheel set about all the way in.The 9W has a longer pitman and frame and doesn't need the wheel moved in.I had a 9W for a long time and I really liked it.Unfortunately I crossed a ditch the wrong way and broke the gear case all to pieces.
