Engine revs up uncontrollably
Terry L Hurless
05-26-2005 06:20:50
I have an LX188 and all of a sudden the engine starts revving up uncontrollably. The throttle cable is still connected but doesn't really control the rpms. It will choke it out and if you play with it enough it will bring the rpms down temporarily. Do you think this is maybe a carburetor problem or maybe even the clutch.
Bob Collins
05-26-2005 10:37:13
 Re: Engine revs up uncontrollably in reply to Terry L Hurless, 05-26-2005 06:20:50
Here is what I have seen happen to cause your symptom. The screws in the throttle plate work loose and fall out then the throttle plate works its way out of the throttle shaft and the governor can't turn the shaft to control rpm. (Which wouldn't work anyway since the disc is out of position and won't close.) Pull off the air cleaner and look in the throttle bore to see if this is your problem. Fix is obvious.
