830 Power
cowboys013
05-26-2005 04:57:13
I have a 830 two cylinder and was wondering if anyone could tell me how these other guys are getting more horsepower out of thier 830 tractor. I have turned up the fuel rack to the max spec. The engine is sound and smokes very little at full throttle with a load. Can anyone point me in the right direction?
Mike in Shendoah Valley
05-27-2005 20:16:53
 Re: 830 Power in reply to cowboys013, 05-26-2005 04:57:13
You've got to have some serious power to pull in 2nd gear--2 1/2 mph I believe. I threw my fuel screw away,got power and smoke,but the sled still gets me and she never spins,course I got 20.8's on it. Getting it to 100 hp will break um loose I reckon.
720Deere
05-26-2005 10:48:55
It depends on what you are looking for. You can gain a fair amount(8-10 hp) by opening the rack all the way. I assume when you reference max spec, you are not talking about all the way just to the Deere specified limits.
Gpower is a good guy to talk to. For what he can wring out of an R without stroking it, I can only imagine what an 830 will run. I have heard of 100+ hp without major mods other than the fuel system.
Cowboys013
05-27-2005 06:18:36
 Re: 830 Power in reply to 720Deere, 05-26-2005 10:48:55
Yes, I am referencing the max as specified by Deere. I just want to be able to pull in second gear. I have had the front off the ground pulling in second gear in the 11,500 class and ran out of power. Then, first gear in this ole tractor is way to much power to keep the tires from slipping.
PJBROWN
05-26-2005 20:23:36
100 + HP WOW!!!! Would that be through the PTO ???? It sure would be awesome to see a old JD 2 lunger on a double row corn chopper...
buickanddeere
05-27-2005 01:39:55
 Re: 830 Power in reply to PJBROWN, 05-26-2005 20:23:36
That's only 133% of max rated power from a high hour 45+ year old tractor that is rated for 60HP continious. That kind of fun can get expensive.
729Deere
05-27-2005 12:11:03
 Re: 830 Power in reply to buickanddeere, 05-27-2005 01:39:55
The black dash 820 and the 830 were Nebraska tested at 75 hp on the pto. The 80 and early 820 were tested at 67 hp. I think everyone would agree that if you are pushing 100 hp out of an 830, you are not going to "work" the tractor. It is merely a toy at that point. I know you will preach about longevity issues and such, but Hendricks doesn't expect 150,000 miles out of one of their NASCAR engines. People looking for power are usually willing to make that sacrifice.
If you thing that 100 hp is extreme, there was an 830 pulling unit for sale a few months ago that boasted of 1100+ cubic inches and 200 hp!
buickanddeere
05-27-2005 22:40:25
 Re: 830 Power in reply to 729Deere, 05-27-2005 12:11:03
133% of 75HP is 100HP 80% of 75 HP is 60HP which is what the operators manual says to use the tractor at on a continuos basis. That's 20% in reserve for tough spots.
Gpower
05-26-2005 09:55:42
Drop me a line, well talk about it.
GP
GPULLER
05-26-2005 06:54:37
You need to talk to Garry Power. He's the man to talk to about 2-cylinder fuel systems. From stock to modified. He built some injectors for my 720 and calibrated the the pumps to the modified injectors. I'm real happy with the results. If you have questions send me an e-mail.
mike brown
05-26-2005 05:26:05
If you haven't backed out the rack adjustment as far as you can try that. I don't know if the specs to which you refer mean backing that screw all the way out or not. It'll smoke more and make more power at full load if your injectors and pumps are fresh. If the pumps and injectors haven't been rebuilt in a long time have that done and tell them you plan on pulling it . You can lighten the spring on the governor that controls respose to load pulling down rpms and it'll go to full throttle a little quicker when rpms start to drop.
You can try these things without harming that rugged old tractor.
