Battery/Charging Problem
Mario Mariani
05-25-2005 19:14:28
Thanx John for all the info. I did all you said to try & everything seems to be in order.The only thing I found strange was when I did a voltage test at the battery posts with a neg ground the voltage stayed the same at all speeds of motor & when I disconnected the battery & did voltage test,& the voltage went up & down with motor speed so there is power coming from motor, but it was pos ground. This part I do not understand! Can you help with this Thanx agan.
John T
05-25-2005 20:04:32
 Re: Battery/Charging Problem in reply to Mario Mariani, 05-25-2005 19:14:28
Mario, its sounding to me like that rectifier/regulator may be the culprit. If loaded properly with a good rectifier/regulator I think the AC output from that stator is in the 20 volt AC vicinity and theres something like 13 or so DC after its rectified. If any of the diodes are bad or shorted it can cause all sort of unusual AC/DC readings and NOT be capable of supplying DC which is whats needed to charge the battery instead of discharge it. Is that rectifier/regulator block well grounded?? I think they are but not sure of all or yours, sorry. I guess its wired correct?? The ones Im familiar with have 2 wires in (AC side) from the stator with one out (DC) to the ammeter/battery, often the red one.
So long as the 2 wires to the AC stator are continuous but NOT shorted to the engines frame its probably okay leaving the rectifier/regulatr often as the problem IF ALL ELSE IS OKAY??
Put me on a regular tractor DC charging system and Im pretty decent but not knowing your mower and whats exactly inside that rectifier (assuming it has one) Im kinda at a disadvantage over the net, you need an experienced lawn tractor guy here, thats not me. When I had bad ones I usually picked up a used one at a lawn tractor shop from a junked engine and they worked.
Hang in there, hopefully a good mower man who knows your particular tractor can help, Im kinda guesing and making assumptions which may be off base??
John T
