G won't start
farmallman
05-25-2005 17:14:27
I tried to start my G today, but it didn"t wanna start. It"s got fuel, battery power (as well as towing) but it won"t go. I think it is my Carb b/c a few months ago (Christmas holidays) i rebuilt it...it did run, but stalled a few minutes later..... and now i"m stumped....
anybody have any advice/things to check?????
Thanks
John T
05-25-2005 18:29:22
 Re: G won't start in reply to farmallman, 05-25-2005 17:14:27
Are the plugs firing?? If not are the plug wires at least firing?? What Ignition is it, Mag or Distributor?? I ask about ignition cuz you say shes got gas and I assume it has compression, if shes sat a long time it may help to squirt some oil in the cylinders or even pull start her. Fuel, Fire n Compression shes gotta have, see if you can narrow that down a bit by first seeing if shes firing and we will go from there. If shes not firing its usually the points are oxide coated (run a dollar bill between them and check gap) or maybe worse like burned or pitted or carboned up (replace them) unless the plugs are fouled out, how they look??
John T in Indiana
farmallman
05-26-2005 10:09:20
 Re: G won't start in reply to John T, 05-25-2005 18:29:22
I never thought to check my plugs...i think it is a distributor, i think....i had the cock valves (i think that is what they r caled) open, should i have closed them?
THANKS
John T
05-26-2005 11:12:29
 Re: G won't start in reply to farmallman, 05-26-2005 10:09:20
Opening the Petcocks reduces compression for easier cranking, which can increase the starting spark energy somewhat on battery powered coil/distributor ignitions (dont drag battery voltage down as much), its worth a try. Thats more for hand start tractors. However, with a good heavy duty charged battery n cables and a well tuned ignition, I seldom if ever used the petcocks on battery start tractors unless the battery was getting low.
DEFINITELY check or better yet install new plugs and if its a Delco battery powered Coil/Distributor the points gap is around 0.023 on high cam, plus non abrasively clean/buff/polish them with a dollar bill and clean the cap area out well and with new plugs see if they fire??? Have fresh clean water free gas and insure the air cleaners lower bowl isnt full of water.
Let us know
John T
