2840 trans safety switch
Steve Ga
05-25-2005 14:39:15
I have been working on stopping some leaks.took off baterry box and removed some platform(no cab)panels.Put back together and it wont turn over. Where is the trans. safety switch?I assume I have hit it or something. Some of the lights wiring is not connected,but it has been starting fine.is there a fuse?
Super A
05-26-2005 10:01:51
 Re: 2840 trans safety switch in reply to Steve Ga, 05-25-2005 14:39:15
If it's like the 2940, the switch will be on top of the trans. housing directly below the center part of the platform. Should be a plastic connector with two wires leading from it. On the 2940 you can reach it by removing the bat. box cover on the LH side. I had the same thing happen once---was doing some cleaning under there, servicing batteries, etc. and when I was done the tractor was dead. Got to checking and sure enough, I had accidentally knocked the connector off the top of the switch. Plugged it back in and she fired right up!
Again this is on a 2940. Not sure if it's in the same place on a 28 but I would guess it is close. Might go to deere.com and pull up the parts book on the 2840 to make sure.
Al
