B or H rear lift
tsst1
05-25-2005 09:13:25
Did Deere make a 3point style hyraulic lift for the H or B?
JDVan
05-27-2005 23:47:40
 Re: B or H rear lift in reply to tsst1, 05-25-2005 09:13:25
John Deere made 800 series hitches for the late lettered series but primarily for the 50, 60 and 70. JD did not recommend using these hitches on the A & B due to the fact that the pressed steel front ends on those tractors were too light for lifting heavy three point implements. However, many where installed on A's and B's and within certain weight limits worked ok. Late G's were approved by JD as they retained the cast front frame and were heavier in the front end and had heavier lift capacity.
I'm not aware of JD offering any kind of three point hitch for the H. However, I have seen a home made one using a hydraulic cylinder driven off the optional hydraulic pump for an H. Not very practical however.
Any aftermarket three point hitches installed on the A's and B's would have the same implement weight limitations. John Deere did not offer front frame weights for the late lettered series however did offer front wheel weights but they by themselves were really not adequate to the job.
If you are interesed in learning about 800 series hitches see:
Link
Mathias NY
05-27-2005 04:28:03
I don't know if Deere made a 3pt specifically for a 'B', but I believe the setup off of a 50 or 520 would fit with little modification. We used to have on our '49 'B'.
www.saginawcountytractor.com sells new ones for about $500.
I know of no such lift for an 'H'
