37A oil pump
Leo
02-24-2004 08:20:49
Guys , on prior posts I read that the oil pickup has a screen that may clog up.
is there a way to get to that screen from under the tractor ? or do I have to open one of the access covers on top of the crank case ? in any case , will I need a new gasket when I put that cover back on ? I am a bit far from an agricultural JD dealer and am afraid to take the covers off for I may not find a replacement gasket. anyway,I do have oil pressure but the tractor sat so long that I kind of want to make sure everything in there is clean .
thanks leo
Clooney
02-24-2004 09:03:17
 Re: 37A oil pump in reply to Leo, 02-24-2004 08:20:49
Leo, that pump pick up screen is hooked around the oil pump in the bottom of the crankcase so you will have to drain the oil then pull the crankcase top cover & reach down in the bottom & feel around the oil pump screen.. I use a small garden sprayer with kerosene in it to clean & soften the gunk around that pump intake screen.. There will be oil lines in the way as well as having to reach around the crankshaft & rods. If you find a lot of junk in there you should then pull the oil lines going to the pump & then remove the bottom pump bolts from under the crankcase & pull the pump down & out the bottom [don't loose the pump shaft upper coupler] as you will have to re-install that when the pump goes back in..
~On the gasket for the top cover , you have a few choices there.. One is to buy a new one from Deere, another is to just make one using bulk gasket material & the top cover as a template, the 3rd is using a silicone type gasket maker like RTV or similar.. I hate that gasket silicone sealer but it will work if needed.
~If you pull the oil pump out the bottom you will need new gaskets from Deere as the pump cover to pump body gasket is critical to thickness or the pump might not work correctly..
[email protected]
