12/24V series parallel switch in 730D
mike brown
05-24-2005 17:29:03
I read about this switch here a while back and bought one to try in my 730D es. Has any one done this? If so any advice would be appreciated.
They have a number of different installation directions depending on what type of electrical set up you have, say a '47-'54 Kaiser. The one that seems the closest reads...positive ground, simple selnoid starter switch with single wire push button and bendix starter.
My tractor had the split polarity system removed a couple of owners ago. They installed an alternator and moved the battery cables to series to start then to parallel when running . I want to accomplish the same thing with this switch.
Thanks
CFWelles
05-24-2005 18:25:19
 Re: 12/24V series parallel switch in 730D in reply to mike brown, 05-24-2005 17:29:03
Mike,
Please comment on the source for the switch you are referring to. I have an original switch that is not fully operational. Before I try to repair it, thought I should look for suitable replacements and send the original to an expert repairman. Thanks.
mike brown
05-25-2005 05:36:16
 Re: 12/24V series parallel switch in 730D in reply to CFWelles, 05-24-2005 18:25:19
J.C.Whitney. I belive it is an Orpin switch made in Ca. I'm at work and the unit is at home so I can't give ou more info until later.
mike brown
05-25-2005 15:34:14
 Re: 12/24V series parallel switch in 730D in reply to mike brown, 05-25-2005 05:36:16
It's an Orpin model c 12/24 series-parallel switch. Inside the instruction book is a sticker that says Automatic Battery Corporation of America, 411 Matheson St. Heraldsburg. Ca.95448.
If you connect two 12v batteries in series (24v) to start the tractor then rearrange the battery cables so the batteries are connected in parallel(12v) to run lights and charge from a 12v generator you are manually doing what this switch does instantly with the push of the starter button.
I'm figureing out how to hook it up for this application since it isn't specificly covered in the instruction book.
If you are refering to the switch on the dash, this is different.
CFWelles
06-05-2005 04:17:10
 Re: 12/24V series parallel switch in 730D in reply to mike brown, 05-25-2005 15:34:14
Mike, thanks for the followup. I have a Whitney catalog and will take a look. I bought a spare 24V generator off a fellow on Ebay and have a really good repair shop near here. I am going the route of wiring my 730 as close to original as I can get it. Am considering finding another takeoff oriiginal dash mounted ignition switch and rebuilding it. Only item on my switch that is not working is the step down resistor function for the lights. This just a correctly sized resistor. Should be able to replace the resistor if that is what is bad. I believe the resistor is externally mounted on the back of the switch. Your approach sounds really good, but I am going for originality as much as I can.
