4010 brakes
ronblan
05-24-2005 14:38:59
hydraulics were working slowly. to make a long story short the sump screen was stopped up with brass colored chips and grey like matter. I drained fluid and replaced sump screen and hydraulic filter and put in new fluid. I have used the tractor the past week working in hay. drained fluid again and checked screen. there was very little signs of chips on screen. hydraulics seem to work ok but not as strong as they were before the problem started. has anyone out there had this problem and what are my chances that the brakes may not flake off as much again?
Gerald J.
05-24-2005 15:01:19
 Re: 4010 brakes in reply to ronblan, 05-24-2005 14:38:59
Brake pads break up from the wrong oil. Are you now using proper JD approved oil?
Gerald J.
ron blan
05-25-2005 08:51:48
 Re: 4010 brakes in reply to Gerald J., 05-24-2005 15:01:19
yes ive always used approved oil. the only thing that happened over the early winter months was the oil got murky looking like it might have gotten moisture in it. I didnt let it go to very long before it was changed out. It is clear now.
