44 John Deere A (to pull or not to pull)
Eric Warrington
02-24-2004 07:43:27
I am considering making a puller out of a decent 44 A. Iv`e been told that any A with round axle housings is too weak to pull. Also wondering if the long hood makes this tractor more or less valuable than other styles. Does anyone know the aproximate value of this tractor? It is complete, running, and restorable. Thanks, Eric
The Rodent
02-24-2004 17:42:19
 Re: 44 John Deere A (to pull or not to pull) in reply to Eric Warrington, 02-24-2004 07:43:27
Eric, you should pull your 44 A it might not be a hot roder if you pull it in first.But I pull a 38 A, and have friends who pull JD A's built in the 40's. I'll pull fine, maybe a little slow.
Eric W
02-24-2004 19:59:56
 Re: Re: 44 John Deere A (to pull or not to pull in reply to The Rodent , 02-24-2004 17:42:19
Thanks for the info, I have a chance to buy a styled G that my late uncle built to pull. Which would make a better puller A or G .Also where is a good place to buy pressed steel to fit these.
T
The Rodent
02-24-2004 17:43:31
Correction: It'll pull fine, maybe a little slow.
deereman
02-24-2004 13:02:46
My 44 A doesn't go fast in 1st. My tractor was a pulling tractor until I bought it.
ronjohn
02-24-2004 07:55:16
not to pull!!!. the longhood A's are a little rarer than the others, that tractor has to high of a first gear for pulling,unless you dump a bunch of money into the engine. you can buy a newer a with the low first gear for a good price now aday, i would save the longhood and make it a show tractor
