UK 4430 tappets
charles
02-24-2004 07:17:01
The tech manual gives full details for checking valve clearances , but does not mention if the engine should be hot or cold . Does it not matter? I have just aquired the tractor and don't know it's history but it seems to have been very well maintained , starts very well even below freezing and tappets don't sound noisy . Do I really need to check them , I bet most people don't ! Do they wear tighter or looser ? (I would prefer not to do this job) thanks in advance
G-MAN
02-24-2004 07:53:09
 Re: UK 4430 tappets in reply to charles, 02-24-2004 07:17:01
Adjust the valve lash with the engine cold. Preferrably dead cold, but anything under 100 degrees or so should be okay. There's enough "give" in the specs that it's pretty hard to get them wrong. I've seen them wear tighter AND looser on the same engine. It just depends on if the valve is recessing into the head some (making lash tighter) or if the valve tips or rocker tips, or cam lobes are wearing (making them looser). I would check them just for insurance. Valve cover gaskets are cheap, and it takes little time. Once you know they're correct, you shouldn't need to check them for another 2000 hours or so.
