How does the third member connect to implements
Corky
05-24-2005 08:00:21
My recently purchased JD 4010 has a third member with a hook on the end. How does that connect to three point implements?
j cook (iowa)
05-24-2005 10:42:00
 Re: How does the third member connect to implement in reply to Corky, 05-24-2005 08:00:21
It's called a "Top Link" and it attaches to the implement, usually by means of a "mast" or upright bar which becomes the upper attachment point. The hook on the end fits over a "ball" fitting" which will look sort of like that found on a trailer hitch, There is a release lever on the end of the "hook" which moves a latching pin, allowing the "hook" to fit over the "ball" and then latch in place. Have you no pictures in owner's manuals? Those books full illustrate what is meant, and how this system works.
John T
05-24-2005 08:09:15
Corky, when using those hook type top links, you have to have the matching sized ball attached (via a pin) on your implement there at the top. Then on your top link, you pull the lever to release the latch and the hook drops down over and secures to the ball which is attached on the top of the implement.
Clear as mud?? You simply gotta use the matching ball mounted to the top of your 3 point implement with those hook type top links.
Ol John T
