Battery Voltage and + or - Ground J.D. S.N. 620703
Captain Buford
05-24-2005 06:18:00
Richard bought a John Deere tractor recently. The Serial Number is 6207033. Richard is not sure what year it is. He would like to know when it came from the Factory New was it 6 volt or 12 Volt? The second question is was it wired positive or negative ground? Any correct answers would be appreciated.
Kevin L.
05-24-2005 11:02:38
 Re: Battery Voltage and + or - Ground J.D. S.N. 62 in reply to Captain Buford, 05-24-2005 06:18:00
my card shows the serial number to belong to a 1957 620 and originally was 12 volts positive ground and think most were 12 volts, unless someone has changed or modified it.
Captain Buford
05-24-2005 14:21:47
 Re: Battery Voltage and + or - Ground J.D. S.N. 62 in reply to Kevin L., 05-24-2005 11:02:38
Kevin L Thank you I am sure you are right on all your info. Captain Buford
Kevin L.
05-24-2005 11:06:32
oops, on someone part...
serial no 620703 belong to a 1949 'A'
serial no 6207033 belong to a 1957 '620'
Captain Buford
05-24-2005 14:18:40
 Re: Battery Voltage and + or - Ground J.D. S.N. 62 in reply to Kevin L., 05-24-2005 11:06:32
Thanks Kevin L I think you are right on everything. Captain Buford
WTW
05-24-2005 06:31:19
It would help me if you could tell me what the model of your tractor of concern is?? If it is an "A" or a "620" it came from the factory 12 Volt Positive ground. DW
Captain Buford
05-24-2005 14:27:32
 Re: Battery Voltage and + or - Ground J.D. S.N. 62 in reply to WTW, 05-24-2005 06:31:19
WTW Sorry I forgot to mention the Model Number. My cousin did say it was a 620. I assumed because the first 3 letters of the Serial Number were 620 that was the model but it may not be true in all cases Captain Buford
