730lp side panel questions
Cotton Picker
05-23-2005 19:14:23
Just bought a 730lp, does not have the "side panels" that go along the bottom of the lp tank. Will the panels on a 630lp work? What is the correct placement of the 730 decal? On the top or bottom of the front yellow panel?
CLW
05-23-2005 20:17:34
 Re: 730lp side panel questions in reply to Cotton Picker, 05-23-2005 19:14:23
The side panels "Hood Extension" in parts book for a 630LP are part numbers AR20786R for right side and AR20787R for left. Maybe someone with a 730 parts book can check these numbers against the 730. The decal goes on the yellow paint. I can check tomorrow and give you the proper location if you need it.
CLW
Cotton picker
05-24-2005 06:46:22
 Re: 730lp side panel questions in reply to CLW, 05-23-2005 20:17:34
Found out the 730lp part numbers are:
RH AR 20608 R
LH AR 20609 R
I know they were both built on the same frame, I found some I can buy off a 630. $25 is worth taking the risk, I can always resell them.
David from Kansas
05-24-2005 05:50:53
CLW,
I'm just about ready to put decals on my 730 LP standard and would like to know exactly where the "730" and "John Deere" decals are placed. The originals on the tractor had been painted over so I have nothing to reference. Thanks.
David
CLW
05-24-2005 11:42:50
 Re: 730lp side panel questions in reply to David from Kansas, 05-24-2005 05:50:53
David, the 730 decal will start 3" to the rear of the forward edge of the grille and 2" down from the top of the yellow paint. The "John Deere" decal will start 2" back of the seam of the grille and hood. Top of the decal will be even with the top of the 730 decal. The name "John" will be on the hood and "Deere" will be on the extension hood (side panel) ending near the seam on the LP tank on the flywheel side. On the pully side the hood and grille seam will be between the D and E of the name D/eere. The decals are farther forward on LP models than gas or diesel models.
CLW
David from Kansas
05-25-2005 20:09:08
 Re: 730lp side panel questions in reply to CLW, 05-24-2005 11:42:50
Thanks, CLW. That is a great help. Hope to get decals on before Saturday.
