70 power trol
Hilltopper
05-23-2005 18:00:47
I am having hydrulic peoblems on my 70 gas with 45 Loader. I noticed the lift was slow and weak on the loader. It is plugged in to the remote outlets. I pulled the loader and checked the pressure. It was low. I increased the pressure to about 1200 which I know this is high. This proves the pump is O.K. I then pulled the the rear unit and replaced the cylinder o-ring which seemed a little stiff. I also replaced the gasket which was not blown. This eliminated all the possible internal cylinder problems. The valve on the left side is screwed all the way out for use of the remote cylinders on the loader. None of the above solved the problem. I tried to disc with it and it could not raise the diac with remote cylinder. I tried moving round bales with it and it cannot lift them. I have been using this tractor for several years. This is a new thing. There does not seem to be enough pressure to the power trol to cause the lever to pop back as before underload. Another thing,I can move the lever forward to lift and it will do so, however if I push the lever full forward under heavy lifting the lift will go down instead of up. I hope there is a simple answer to this. I use the loader alot. Thanks for any help.
