G-man
greg S
05-23-2005 06:38:48
I get an intermittant code on my 4255 when I strart it up. Display says see code 5. Any ideas.
Thanks.
G/MAN
05-23-2005 10:24:36
 Re: G-man in reply to greg S, 05-23-2005 06:38:48
I can do some more digging, but I didn't find a code "5" in the 4255 book. Some of the large-frame 55s (4555/4755/4955) have the electronic injection pump and they all have the electronic hitch, so the large-frames have a bunch more possible codes. Your 4255 has a mechanical pump and the mechanical hitch, so the only codes available on your tractor are the SLF codes, or codes relating to the tachometer itself. Are you getting any warning lights or anything at the same time?
greg S
05-24-2005 06:00:51
 Re: G-man in reply to G/MAN, 05-23-2005 10:24:36
No warning lights or any other alarms. Only shows up when I first turn the key on and then only very intermitantly. Could be an internal tach/moniter error, tractor doesn't have radar or any thing else. Thanks for looking, next time I talk to my local service guy I'll ask him (if I remember).
G/MAN
05-24-2005 10:21:43
 Re: G-man in reply to greg S, 05-24-2005 06:00:51
Since the dash panels pop right off on the 50-series and newer tractors, I'd pull them off and unscrew the tachometer and performance-monitor modules. Make sure the twist-lock connectors are tight. Now that I think about it, I seem to recall working on a 4955 or some such that had some goofy things going on. Turned out to be nothing more than a loose connection at either the tach or perf. monitor. I can't remember which.
greg S
05-25-2005 05:56:48
 Re: G-man in reply to G/MAN, 05-24-2005 10:21:43
Thanks, I'll try that. I've have a grounding problem on those modules for sometime. When I took it in the last time for the winter special the mechanic added some grounds. At least the 55's aren't as bad as the 00 series, lose the moniter/tach unit and there it sets.
