Kurt, I am working on an early B but I just checked the parts book concerning later B"s. All the B"s had a pressure fed oil line to the governor. If you have the governor off, look down into the engine housing, there should be a line coming up feeding the governor. To get the governor off, you should have had to removed the engine access cover and reach in to remove the line. Did you have good oil pressure? Would make sense your bearings are gone if the line was left disconnected. I just did my governor and invested in a 20 ton press to remove the gears, bearings, etc. You do need to remove the gears and bearings from the shaft. Hammers work but the press is slick and not near as abusive. You might want to check for excessive play in the lever shaft. (the shaft the throttle linkages connect too) Mine was really sloppy. The bushing in the governor case was really worn and the shaft itself had plenty of wear. JD had the bushing; I had a new shaft cut out of round stock. Bearing and parts are available from JD, at least most of them. The governor main shaft is under spring tension. Once you have the bearings replaced the flywheel side cover can be installed by drawing it up with the bolts. That"s why the magneto or distributor needs to be removed when installing this cover. Sounds like the bad bearings had everything just falling apart. With new bearings it shouldn"t be a problem. To clean out the main case, I would pull the oil pump. Sounds like you might have some finer debris down there if the bearings fell apart and the gears are worn that badly. With the pump out you can clean the sump screen that wraps around the pump assembly and reach up from the bottom to wash the case. It"s only 3 bolts, gasket (or Permatex), and an oil line. The oil pump drive coupling can be checked at the same time. Hope this helps, I"m not an expert (expressed or implied) just some things I learned on my project. I have a lot more to learn!
