4020 fusible link on ground keeps burning up
Chris Ammons
05-22-2005 16:23:08
My father in law has 3 4020s. -64, 65, & a 66. The 65 and 66 keep blowing the fusible link on the ground that goes from the battery to chassis. The lights do not work on one side. I do not understand how it is wired with the 24 V system. Can someone explain to me what needs to be checked?
Thanks,
Chris
ck92
06-20-2005 07:16:22
 Re: 4020 fusible link on ground keeps burning up in reply to Chris Ammons, 05-22-2005 16:23:08
I have a 24 volt 4020(66 model with powershift). I wouldn't change to 12 volt if you live in a cool environment or use it in the winter. I use mine to feed hay in the winter and the 24 volt starter system is much better. I've spent hours working on it though. My suggestion--you have a broke spot in a lamp wire that is grounding out. But it could be a million different little things.
Here is what I eventually did last year and I haven't had any trouble since-- I purchased a 24 volt alternator kit from JOHN DEERE ($275). Then I replaced the starting circuit wiring harnesses with 12 gauge wires. I then replaced each lamp wire and the switch wires. I have a JOHN DEERE service manual that has the wiring diagrams in it and wired the tractor accordingly. I spent $450 on all of this. The cost to convert to 12 volt system is around the same but you still will have the same problems with the old wires and lights. Also, be sure that the lamps are grounded--they have a frame ground. This is just a suggestion but it has solved my problems so far.
Chris Ammons
05-24-2005 04:54:31
I forgot to add that both of these tractors start fine, just the lights do not work right.
One of them has a new starter, the other a new generator.
Chris
Rick S.
05-23-2005 18:12:46
I had that problem on a 3020 with 24 volt system. It can be very hard to isolate the problem, but more that likely it is a short in the starter, if it burns while trying to start the tractor. What I did to solve the fuse problem was to put a circuit breaker. like the ones under the dash, that way it will kick back on, and you will have fuse protection. But if you want to solve the problem permenatly and a lot of other problems, convert it to 12 volt, it is not that costly, about the same as a 24 volt rebuilt starter for a conversion kit.
JGC
05-23-2005 16:45:51
Had a similar problem on a friend's 4020. Turned out to be the starter. They don't fix their own starters so we never did hear the final problem but it was inside the starter/solenoid combo.
By the way, they had their harvester controls hooked up from ground to the +12 volt battery. The heavy load of the harvester's electric clutches and control motors drained the +12 battery and un-balanced the charging system.
Blessings,
Jon
msb
05-22-2005 20:47:59
First think I would check is the thrust washer on the starter shaft.A worn thrust washer will let the commutator hit the end cap of the starter and will burn up the link every time.Look for evidence of arcing on the end cap.
Gerald J.
05-22-2005 16:51:54
There's probably a short in the wiring from on the side the lights don't work. But it could be in the starter or the generator. It could be a lamp.
For starting and charging the system is 24 volts floating with the midpoint of the battery grounded through the fusible link. That gives two 12 volt systems, one positive and one negative. The lights are distributed evenly between the two 12 volt systems so the 24 volt charging system charges the batteries evenly and they are loaded evenly.
For testing, replace the fusible link with a 12 volt test lamp and search the wiring by disconnecting pieces until you find the short. Fix the short. Put the fusible link back. Don't skip unhooking the starter, the starter solenoid, and the generator as part of those disconnections.
Gerald J.
