4230 electrical problem
gorilla
05-22-2005 15:42:28
A couple weeks ago my a/c blower, radio, & wipers quit working. Figured it was a circuit breaker. A couple days later the radio started coming on so I turned on the blower just to see if it was working. When the blower was turned on the radio quit.? Oh well, too busy to fool with it so didnt. Today tractor started just fine & about 15 min. later The blower came on full blast & started blowing dust all in my face & startled the S*** out of me. Shut the tractor off & now everything is dead. Wont start, no lights, signals, dome light... dead as a hammer. Would a bad relay cause this? If so how would I check it? I used an ohm meter & get no reading from any connection to any other. (3 connections, 1 to key switch, & 1 on either side that goes to circuit breakers) It pegs out if I go from the starter switch terminal to the case of the relay.
donmyeil
05-23-2005 06:43:08
 Re: 4230 electrical problem in reply to gorilla, 05-22-2005 15:42:28
Sounds like the cab relay is shot. Its behind the left cowling, looks like a starter relay.
cannonball
05-23-2005 05:08:48
just got done changing the wiring harness from firewall all the way to top of cab...was bare and burned wires..my ac quit and was checking to see where touched them wires and burned my fingers..changed them out..just had 4230 in shop 2 years ago and asked them to check it out if it needed change it well another thing they did not do..be careful and be sure you check under the cab for bad wires...had same thing on 4040....have nice day may god bless
MSM
05-22-2005 16:56:13
There is a heavy gauge red wire that feeds up to the firewall.There is a disconnect plug on it for splitting the tractor.This plug tends to corrode on its contacts and kill electrical power to the cab.Try pulling it apart and cleaning it good. Same thing happened to me on my 4430.
gorilla
05-25-2005 21:08:43
 Re: 4230 electrical problem in reply to MSM, 05-22-2005 16:56:13
Well, it wasnt the relay. It had juice to the circuit breakers but I think a bad connection to one of the batteries was causing the problem. Anyway, it starts now. The problem with the a/c etc turned out to be bearings shot in one of the blower motors. I guess it was locking up and tripping the breakers. Thanks for your help!
