1010 head bolt torque value and sequence
rex
02-24-2004 02:51:32
Anyone out there have the torque value and bolt pattern sequence for head replacement on a 1010 gas above s/n 40000
Dave / Believer45
02-25-2004 16:51:31
 Re: 1010 head bolt torque value and sequence in reply to rex, 02-24-2004 02:51:32
Torque value is 125 ft-lbs, I would go to 50 then 100 then 125.
Sequence is as follows:
10---6---1---3---7
Front 8----4---2---5---9
Manual also cautions if the rocker arm shaft studs were removed make SURE the stud with the machined flat is at the rear, it provides the oil passage for lubriacting the rocker arms. Rocker arm retaining cap screws and stud nuts need to be torqued to 30 ft-lbs.
They also say to run to operating temperature and retorque head bolts.
Valve tappet gap (cold) is .012" intake and .018" exhaust.
Dave / Believer45
rex
02-26-2004 02:17:56
 Re: Re: 1010 head bolt torque value and sequence in reply to Dave / Believer45, 02-25-2004 16:51:31
Thank you for your help I have got this 1010 and an 444 International broke apart in my shed and am trying to get them done and out Thanks Rex
