A/B electronic ignitions
Eself
05-22-2005 07:32:24
I have a 52 B and a 48 A, everyone i talk to says i need to go ahead and put electronic ignitions in them..... ..and where could i get them
ChuckW
05-22-2005 15:26:48
 Re: A/B electronic ignitions in reply to Eself, 05-22-2005 07:32:24
I purchased mine from genessee electronics and would not even consider going back to standard ignition. It is as much improvement in dependability and performance as night and day.
Mike M
05-22-2005 11:54:51
You didn't talk to me, as I say go with points in either a mag .or a delco dist. Points will give you years of service,cost less,and when they fail it is usually gradually not all at once like electronics.
John T
05-22-2005 08:09:02
Pertronix has them www.pertronix.com/. BE SURE AND MATCH YOUR POLARITY as all two cylinder Deeres were originally Positive ground. Whats yours???? In order to get the most bang for the buck from an electronic switch, I highly recommend you couple them with a high energy coil (Pertronix has them also) and run a wider than stock plug gap, maybe in the 0.035 to 0.045 range, check with vendor for coil and plug gap recommendations. There may be some other minor wiring issues involved if you were at 12 volts but use a 6 volt coil and an external voltage dropping ballast resistor.
Ol John T in Indiana
