1963 John Deere 2010 Transmission Leak/PTO Problem
Dustin Tireman
05-22-2005 07:10:43
Hi. I have 1963 John Deere 2010 that I got from my Dad. It has a fairly significant transmission leak. The whole underside of the rear end and draw bar is covered with oil. If you leave it sit anywhere for any length of time a pretty big pool of oil appears. I keep the transmission filled, so it does not run low, but would like to stop this. I can not tell where exactly it is coming from, as there is oil all over. About 7-8 years ago, my Dad had a mechanic look at it and it was going to cost $600 just for a little gasket (you had to buy a whole gasket kit) that needed to be replaced somewhere on the top side of the rear end. Supposedly this oil pools in this area and with a bad gasket, it allows the oil to drain out. I have a JD shop manual, but I am unsure of the exact gasket that I need. Does someone know which gasket it is that needs to be replaced, or an alternate solution to solve this problem.
The PTO on the tractor has not been used for several years, and I went to use it the other day on a manure spreader and the only thing that happens is that I can hear the PTO grind. The handle is adjusted for equal amounts of play on both ends per the book. If I do not have the manure spreader unhooked, the PTO will engage with no grinding. I can turn the PTO drive of the manure spreader over easily with an 18" pipe wrench. Is this problem related to the leaky transmission? If not, is it just an adjustment inside the tractor to fix this?
Any help would be appreciated.
Dustin
Dustin Tireman
05-27-2005 10:07:55
 Re: 1963 John Deere 2010 Transmission Leak/PTO Pro in reply to Dustin Tireman, 05-22-2005 07:10:43
billde,
I hooked the spreader up last night and engaged the PTO. I then turned the engine over. I could not engage the PTO as I was turning it over (per your instructions) as the PTO handle is broke(long story), but I could engage the PTO lever and then turn the engine over. I am not sure if this method makes a difference, but if it doesn't then it means the collar is not moving far enough, which I think there is an adjustment for that inside the rear end? I could still hear the PTO gears grinding when I was doing this test if that helps.
Thanks for your help.
Dustin
billde
05-23-2005 04:48:27
Dustin, sounds like one of two things, either the clutch is not disengaging, or the shift collar is not moving far enough forward. While hooked to the spreader, engine off, move pto lever forward while bumping the starter{pull coil wire}. If the pto engages fully doing this, your clutches are sticking. If it doesn't engage the collar is not moving far enough. Good luck, post back
