70 gas questions
70 PLOWBOY
02-23-2004 23:10:20
Can some one help set me strait IF i understand correctly A 70 all fuel block will bolt up to a gas case right ??IF so then a G block will bolt up to a 70 gas case too then ???will a 70 lp intake and exhaust manifold bolt up to the all fuel head?? What im wondering is if it will bolt together if so then if i find a 70 all fuel head i could use a g block get some pistons made for it for a increase in cubes and still use my intake ,exhaust set up no its not for pulling other than wagon and a plow my block is all ready .125 over insted of sleveing it just wondering if it would work
thanks ROD
buickanddeere
02-24-2004 20:36:36
 Re: 70 gas questions in reply to 70 PLOWBOY, 02-23-2004 23:10:20
The G's block to head bolt pattern is different from the gas/LP 70. The G block is also longer than the 70 gas/LP block. This makes the 7-3 powerblock a high demand item for 70s. There is a company casting new monster bore blocks for G's and 70's. Advertised in most pulling magazines.
70plowboy
02-25-2004 06:11:33
 Re: Re: 70 gas questions in reply to buickanddeere, 02-24-2004 20:36:36
yes i know about jerry`s monster blocks i was just trying to find out if i could use a G block with a 70 all fuel head insted of sleveing the 70`s block How much longer is the G`s block than a 70`s?? DID the gas,lp use the same crankshaft case as the allfuel 70 or were they a differnt bolt pattern???
buickanddeere
02-25-2004 12:28:52
 Re: Re: Re: 70 gas questions in reply to 70plowboy, 02-25-2004 06:11:33
The 70 all fuel is a rare piece and have been grabbed by pullers before the huge ported head was available from Jerry for G's. The crank and rods are the same dimensions for gas, LP and all-fuel 70 and all G's. LP's cranks were made of a better alloy. I don't recall offhand when or if G's went to insert bearings. Lining up the water, aircleaner and linkages makes it a tedious project. Less headaches and won't cost anymore for the new powerblock.
Mark
02-25-2004 09:25:39
I have a 70 all fuel crankcase and crank for sale, the block and head are gone.
Mark
Mark
02-25-2004 09:27:03
 Re: Re: Re: Re: 70 gas questions in reply to Mark, 02-25-2004 09:25:39
Forgot email address.
