Loren, the Autolite 3076 (standard heat range) or 3077 (side wire deep reach hotter) or the equivalent AC 18 are the older 7/8 plugs versus the newer 18mm used on later tractors. If it has the 7/8 plug, I would use the 3077 since they are a tad hotter than the 3076 specified plus have that deeper reach side wire electrode. A good hot BLUE spark as a result of a well tuned mag with a good strong spring and then the correct amount of choking is probably more important than spark plug brand or heat range as far as good starts. The hotter plugs tend to burn off potential fouling deposits maybe better than a colder plug since we seldom use the tractors the way they were designed, which was full loaded at wide open throttle and temps over 180 degrees. HOWEVER, if the plugs are good and clean and not wet fouled, I dont see a hotter plug making them "start" much better than a colder plug, since the plugs are still bone cold at initial start ups. I.E. if shes hard to start and assuming the same general condition (no fouling deposits) I dont see a hotter plug all of a sudden being a miraculous cure all for a hard to start tractor. Still, for longer life and less fouling, I run the hotter plugs myself. For better spark plug advice and opinions, ask for Duane Larson, whom I refer to as the "Spark Plug Guru" Thats all I have to say about that Ol John T in Indiana
