50 clutch: engage or disengage
Trump
05-21-2005 15:12:13
When I park my 50 for the day I always take it out of gear and set the brake. Does it matter about the clutch,sometimes I leave it engaged,sometimes disengaged. But it's always disengaged when I crank it.
John Van Valkenburgh
05-21-2005 16:39:14
 Re: 50 clutch: engage or disengage in reply to Trump, 05-21-2005 15:12:13
The most important thing about those clutches is to leave them engaged and the transmission in Neutral when the engine is running for extended periods (i.e. more than 15 seconds or so). This is because there is a bearing in the clutch mechanism that must rotate at engine speed when the engine is running and the clutch is disengauged. You don't want to put excess wear on that bearing just like you would not want to sit at a red light for a long time with your clutch pressed in and the car in gear.
When the engine is stopped it really does not matter. I personally leave the clutch disengaged. It keeps the clutch springs from being fully compressed all the time. Also in the unlikely event that a child climbs up to play, they are less likely to go for a real ride.
Best Regards,
John
1953 Model 50
Trump
05-21-2005 17:24:21
 Re: 50 clutch: engage or disengage in reply to John Van Valkenburgh, 05-21-2005 16:39:14
Thanks for that information John. Mine is a 1955 50 . I do work this tractor often. No need to worry about the kids climbing on it,at night it's locked up in a barn,during the day if I have to leave it out and unattended,I take the coil wire off.
P Backus
05-22-2005 21:20:11
 Re: 50 clutch: engage or disengage in reply to Trump, 05-21-2005 17:24:21
One other thing to consider about the clutch is that it can become stuck to the pressure plate or flywheel when the clutch is left engaged. Clutch lining material will have metal particles embedded in it and it can rust tight to the other surfaces. Of course this will only happen when the tractor is parked for longer periods of time. Still, I leave mine disengaged unless it's running.
Paul
