1952 JD60 needs PTO parts purchase advice please
Eric Midgette
05-21-2005 10:24:51
Is there a better place to get PTO clutch plates and disks with facing, locking washer, and brake plate with facing than "Deere". Is there a re-facing kit? Furthermore, is there a good way to apply 700 lbs. pressure to the cam? I am not a serious mechanic, just a tinkerer learning as I go.
Eric Midgette
05-21-2005 22:45:22
 Re: 1952 JD60 needs PTO parts purchase advice plea in reply to Eric Midgette, 05-21-2005 10:24:51
Thanks for everyones advice!!!
Steve Ga
05-21-2005 17:02:04
Do you have the housing off?what do the disc look like. I have a rear end off of a 60,I had bought for the power steering pump.The clutch pack on it is good I bet.Not trying to sell,if its good you can have.I would have to pull off and look at disc,Steve
PeteNY
05-21-2005 16:07:25
Eric, Hard to beat OEM parts, they may cost a little more, but they always fit...100% Problem w/ tractor supply parts is ya spend so much time and effort making them work(enlarging a hole here, grinding a groove there) ya wish ya had bought the JD parts.
Glen in TX
05-21-2005 11:46:03
Some of the tractor supply places have them. They probably have some on here too in parts section. I think you mean 70 lbs. pressure and adjust to where you have a good snap but not binding the clutch up.
